Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
not charging and taking along time to boot to home screen
@refectio i have an issue with this iphone 6. when i got it, it wouldnt boot. on dc and charger with battery disconnected it took around 0.23 amps. i removed tristar and tried dc again and got apple logo. put a new tristar on and as soon as the amps reach around 0.83 the phone restarts. it now eventually boots to the home screen after a few minutes but it wont charge, not showing the lighting symbol in the battery and it stays at 1%. i have already changed tigris aswell, tried a different cable, battery and port. do you have any ideas
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Выбранное решение
Hey Daniel. Did this phone just die out of the blue (the famous nightstand issue ;>) or was it dropped or came into contact with liquid?
You should probe around the charge circuit again looking for any anomalies. Specifically, check the SWI line (battery) and C1402/L1401 in the Tigris area. However, the fact that the phone takes a while to boot could be an indication that there is another issue at play here. Seeing as how you have already changed pretty much everything in the charge circuit, I would check out the PMIC and BBPMU outputs to see if another subsystem is causing any issues to the boot process.
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
The pp3v3_acc cap above Tristar was short. All good now. Thanks for the advice tho
из
@refectio I have a 6s here I replaced the lcd fpc on. Came on fine then I put it on charge and it was charging fine. Came back and stuck on apple logo. Replaced tristar and tigris and all nand voltages are normal. Any ideas
из
Good news and bad news Bad news i only have the answer to 1 of your problems. and that problem is the battery problem. My sister has this problem. All you need to do is change the battery
Оценка 0
1 Комментарий:
Was nothing to do with the battery there was a short on the board. Working now. But thanks
из
@refectio
Hi,
i have a similar problem with an iphone 6. I have a question for you. What do you mean by “check c1402 and l1401” ? I have 4.38v on one side of that coil and 3.88 on the other side. Please help me because I don’t know what do try anymore. Already replaced tigris, tristar, checked all the voltages nearby and they all seem fine.
Оценка 0
Добавьте свой ответ
daniel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 95
