Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
24вопросов Показать все
1005HA LVDS cable: Is 14G2235HA10 equal to 1422-00ML000?
Hi.
Looking for a replacement LVDS display cable for my EEE PC 1005HA. It takes a 14G2235HA10, and I've seen some vendors advertise a cable labeled with both this number and 1422-00ML000. Other vendors use just one or the other of these numbers.
Anyone know whether the 14G2235HA10 and the 1422-00ML000 are exactly the same cable with the same connectors?
The ASUS support site lists only the former number (http://support.asus.com/Search/KDetail.a...).
Thanks for your help.
--Frank
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
My research suggests that the cable is the same but it is based on the information supplied by various vendors I have found on the internet - much like you have. I'd stick to the primary number on the faulty cable and/or the number provided by ASUS
Update
Thanks much, Richdave! I took a chance and am happy to be able to answer this question affirmatively: the 14G2235HA10 IS apparently equivalent to the 1422-00ML000 cable.
Был ли этот ответ полезен?
Оценка 4
yes, they are compatible lcd cable
Оценка 0
Добавьте свой ответ
Frank DeSanto будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 3,230
