Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597вопросов Показать все
MacBook refuses to show any signs of charging or life.
Dear beloved iFixIt,
Statement of the Problem:
My Macbook unfortunately is not turning on, Not charging battery - only green light. Feels like a bricked device on my table here. No chimes, no lights, nothing seems to be working.
How it occurred:
On a very busy day, as I was about to leave home to another town, even though I had just 5% left, I forgot to shutdown my MacBook and closed the lid to deep sleep. 5 days later I reached home to obviously find the MacBook dead. Thinking this is just a battery-no-charge problem, I plugged in my device to find the MacBook not charging and not turning ON.
What I have done everything since:
I tried almost everything I could find in the internet regarding MacBooks not switching on. I did the SMC reset, I did various key combinations found online, I removed the back cover reset the Ram, disconnected and reconnected the battery, tried different chargers, replaced DC power jack board. Nothing seems to work.
Clarifications:
  1. Absolutely no water damage
  2. Airport card not working - I therefore disconnected the card permanently.. worked fine without it for almost 3 months.
  3. Upgraded to 16gb Ram, 256Gb SSD and 1TB HDD about 1 year ago.. worked fine till recently.
I literally have a sitting INR 1.3 lakhs paper weight/brick infront of me.
Please help ..
Thank you so much in advance…
Your ideas will highly be appreciated…
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
You have there a 6+ years old battery that was left drained for a few days..that’s enough to kill a battery sometimes, especially if its condition was not so good anymore. Try unplugging the battery from the Mac and connect the magsafe; you should get a spontaneous boot. If not but you have still the green light showing up it might be a logic board issue.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I have tried this... Disconnected the battery... Tried to boot with the charger itself... But no signs of life....
Thank You...
из
Добавьте свой ответ
Victor Ashish будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 4
За всё время: 116
