LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146вопросов Показать все
Is it possible to replace a contact spring on Motherboard?
Hi:
I received an LG G5 model VS987 phone. It was reported the power button did not function but on closer inspection I found 3 contact springs on the motherboard that are broken- these connect with the power button on the back panel. I have safely removed the 3 broken contact springs, and removed three good ones from another motherboard for replacements. But, how can I safely solder the new contacts to the good motherboard? Anyone done this already?
Thanks!
Tom
Это хороший вопрос?
Оценка 0
1 Комментарий
Thanks for your input…
Actually I`ve started researching SMD rework stations (uses hot air), that is how I will go. All this is still a bit new to me.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Just use good tweezers and hot air at about 450c should do the
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Is there a video you can post on where the motherboard is broken? I have the same issue with my power button which I've already replaced yet it is still not working.
из
Добавьте свой ответ
Tom будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 217
