How to diagnose the issue with an iPod Classic 80GB?
When turned on makes repeating noise and shows (www. apple.com/support/ipod) web address. Replaced the battery a while back.
Это хороший вопрос?
Это хороший вопрос?
It seems like the harddisk is damaged. Try restoring it if you can or you can try checking the harddrive sector here's the YouTube video try that if you have lot of pending sectors you have to replace the harddrive. You can look into iflash adapters https://youtu.be/ayVJRMcUE5M
Был ли этот ответ полезен?
Sounds like the hard drive is dead. You will need to replace it, either with another hard drive, or with a compact flash card or SD card using adaptors like these: https://www.iflash.xyz
Here’s the repair guide: iPod Classic Hard Drive Replacement
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 85
1 Комментарий
Do you have a Mac you can connect it to?
из mayer
