The Kenmore Direct Drive is a washing machine by Kenmore.
spin cycle abnormal noise
when the washer commences with the spin the drum far too easily starts to make that annoying noise that the drum is not balanced and sometimes sounds like it would brake or explode ! ? ? what could make this happen besides a unbalanced load
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Please give us your exact model number to help narrow the problem.
Cause 1
Rear Drum with Bearing
The rear drum has a bearing or bearings in it to keep the inner tub spinning smoothly. If the tub bearing system is defective the washer can become very noisy. On some machines bearings are sold separately from the rear drum, however we recommend replacing both the outer drum and bearing as an assembly if the manufacturer offers the components together because removing and pressing in the new bearing can be exceptionally difficult. Be aware that replacing the outer tub and bearing is also not easy and can be very costly.
Cause 2
Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing.
Cause 3
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Patrick Alvidrez буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 18
За всё время: 298
