Acer Extensa 4630z — это ноутбук, представленный компанией Acer в 2008 году. Серия Acer Extensa представляет собой линейку ноутбуков Acer, предназначенных для деловых и офисных пользователей.
Why is the display not working after I reinstalled the RAM?
I removed and reinstalled the RAM and HDD and powered my laptop and it ceases to display anything. As a matter of fact it was working properly before but was crashing during Windows Xp loading with BSOD, Now the laptop powers on but no display whatsoever.
Это хороший вопрос?
Счет 1
2 Комментариев
@huracanevo are there multiple memory module installed?
test with one stick at a time
из
I only have single RAM but two DIMM
slots
из
Добавить комментарий
2 Ответов
Выбранное решение
It is seem to be only some boot hardware failure. Do you get any system beep sound when you power on laptop. Do one thing. Only install RAM in same slot where it was working before. Do not install HDD. Now power on laptop. Also inform any LED on display turn on or now.
I think ram is not properly installed or hdd is not properly fixed. Inform us what is system sound or beep sound when turn on.
Был ли этот ответ полезен?
Счет 1
3 Комментариев:
There are no beeping hardware internally installed .... there are LEDs indicating HDD ........ I will give it a try
из
Display should work no matter HDD is installed or not ,right Its just the RAM that display is affected
из
Did it and no sign of display working..........But the first time I press power button it powers up ...shuts down for a while and then powers up again......What is the cause?
из
Наиболее полезный ответ
The ram may not be seated in fully or dust is inside the ram slot. Make sure they are seated in well.
Счет 1
3 Комментариев:
No I did it multiple times but the results are same
из
Hi @huracanevo ,
You didn't leave the battery in when you removed / replaced the RAM and HDD did you?
Try a power reset,
remove battery (and charger if inserted) press and hold Power button for 20-30 seconds then release.
Insert charger and switch on charger (leave battery out)
Assuming RAM at least is installed, turn on laptop and check if display works.
из
I actually went through Youtube videos that said static could be the cause of display not working......I did that multiple times as well ...no luck
из
Добавьте свой ответ
Namaste Holiday буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 30
За всё время: 805
