Model M7572 / 400 or 500 MHz G3 processor
Why is my keyboard not responding?
The following keys: 2, w, s, x, keys all quit working after I dripped Iced Tea on a portion of the keyboard. I removed the keyboard, wiped the back off with a soft cloth, re-installed the keyboard but it did not help. I did not see any moisture on the front of back side of the keyboard.
Is there an option to clean the Pismo keyboard, or does it have to be replaced?
Это хороший вопрос?
Счет -1
Добавить комментарий
1 ответ
Выбранное решение
Hook up an external keyboard and see if it works. If it does you will need to replace your onboard keyboard.
Был ли этот ответ полезен?
Счет 3
2 Комментариев:
Thanks Mayer. I did as You recommended. I now have the new onboard keyboard in operation.
из
Glad I could help solve your problem and keep this classic running.
из
Добавьте свой ответ
hlstory буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 836
