Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203вопросов Показать все
Stripped Screw - Early 2009 MacBook
In the process of replacing the optical drive on my early 2009 MacBook 5,2, I stripped this tiny little screw near the RAM slots. I tried everything ifixit suggested in their video already. Nothing worked. Is there any other suggestions? Maybe cutting the bracket?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
The screw is replaceable the bracket is not!
First you’ll need to clean the area of the corrosion from the leaked battery. Try some white vinegar using a moistened cotton swab (Q-Tip)
This screw does have a slight head. I would try grabbing the edge of the screw with a pair of pliers which have a serrated jaw. If that fails then you’ll need to cut a slot into the screen head so a straight blade screwdriver can grab the screw.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Austin Martin будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 42
