Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
Screen wont sit flush
Hello. I changed the charging port and battery and now when i put the screen back on, in the down right corner it doesnt sit flush. Its raised a bit. Please help
Это хороший вопрос?
Счет 0
Добавить комментарий
2 Ответов
Выбранное решение
This is usually caused by how the screen flex cables are aligned. Take a look at the flex coming from the screen and notice that there is a silvery “chip” on the flex. If it isn’t aligned properly, it will impede the way the screen sits on the housing.
Был ли этот ответ полезен?
Счет 3
3 Комментариев:
Where is the silvery chip ? I cant find it. Could you send me a photo of it please ?
из
oh, i know what chip. It seems that the chip from my replacement screen is a bit bigger than the one on the original one. What should i do with it ?
из
The arrow of the "Start Guide" practically points to it :>). Sometimes it just needs to be moved over a little bit until it rests in the opposite "hole" properly.
из
Did you use this because without it, it can cause it to pop up a little. iPhone 7 Display Assembly Adhesive
This custom cut adhesive film secures the front screen display assembly to the case of an iPhone 7. Изображение
Товар
Счет 0
7 Комментариев:
No I didnt but i dont think its the solution. I noticed that the silvery chip on the flex cable is a bit larger than the one on the original screen. I think it doesnt fit in because its too big. What should I do about it ?
из
Where did you get the screen from ifixit?
из
Ok if you didn't get it from here then get this. iPhone 7 Screen iPhone 7 Display Assembly Adhesive
из
OK, thanks :D
из
Keep me updated on how it goes.
из
Показать ещё 2 комментариев
Добавьте свой ответ
Martin буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 205
