Movies, music, multimedia in your home. Use our guides to repair home entertainment devices from surround sound A/V receivers or conventional stereo receivers to power amplifiers, preamplifier, speakers, and iPod/Bluetooth speaker systems.
4606вопросов Показать все
music through speakers on stereo misses some instruments
I have a Sanyo record player and tape deck attached to a computer, the music is not what it should be, with some instrumentation missing or very faint. One example is the harmonica/mouth organ on the Dean Martin hit “Little Ole Winedrinker Me”. The voices and most instruments come through as well as they should.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
If you are feeding these signals into the mic in jack on your computer the “level” is off. Check the following.
Turntable will need a preamp unless it has a line level switch.
On your computer see if you can toggle the audio input to line level and not mic level.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
swabian7 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 96
