LG X Power — это смартфон с поддержкой 4G LTE, выпущенный в августе 2016 года. Данная модель оснащена 16 ГБ встроенной памяти и работает под управлением операционной системы Android.
battery sign with a question mark in it
When i plug in my phone to charge im just getting a battery sign with a question mark in the middle of it? what does that mean?
Это хороший вопрос?
Счет 12
13 Комментариев
My lg q6 alpha is showing the red question sign on the screen I don't what to do
из
What do I need too do if my phone want come on and only show a ? Mark
из
my lg is not turning on
из
I have a lg Stylo phone that I replaced the charging port in which was fairly easy. After getting the phone back together I plugged it in and all it will do is flash the battery sign with a question mark in the middle of it. How do I fix this?
из
I have the same problem in my lg v10 question mark after connecting the charger
из
Показать ещё 8 комментариев
Добавить комментарий
2 Ответов
Выбранное решение
Try a different cable, and charger transformer (plug into pc to charge. A question mark I've seen to be a few different things. Dust in phone charge port, battery took a crap. Or bad charger/transformer
  1. Clean charge port. And cable connection
  2. Replace charger/cable
  3. Replace battery/charge port
Был ли этот ответ полезен?
Счет 6
5 Комментариев:
Hold finger on Questiomark for while..
из
still not working..... im getting mad
из
1 ; either try cleaning battery
2 ; let your phone get cool
3 ; idk
из
If your lg k20 gives you a battery with a red question mark in it 😭😭😭 do a replacement with the battery my grandma's worker at work named Sam said it needs a new battery even with a 2 boxes one with the lg and one with a red question mark ❓ that
из
If u can't turn on the phone after a few seconds of holding down the power button, and the ? Battery when appears don’t disappear when plugging it in. Its probably either the charger or ur phone got overheated where it needs time to cool down for a bit. Once ur able to turn it on by the power cord then its fine. Just keep it out of intense heated places and keep it cool.
Счет 2
2 Комментариев:
If you get anew battery note to remove the stick on the 4 battery connectors
из
im getting the red question mark. i just installed a new battery. please clarify "remove the stick" on the battery connectors. thanks
из
Добавьте свой ответ
Jonathan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 12
За последние 7 дней: 25
За последние 30 дней: 118
За всё время: 58,554
