Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782вопросов Показать все
If I buy an SSD does it comes loaded with the latest IOS software?
I’m looking to upgrade my laptop with an SSD but I’m wondering if they come preloaded with the latest IOS software or if I have to load that into it myself?
Это хороший вопрос?
Оценка 0
1 Комментарий
Just a detail.... Macs don't run iOS, they run macOS. iOS is what's found on the iPhone, iPad, and iPod touch.
из
Добавить комментарий
2 Ответов
Выбранное решение
No one offers preloaded drives and frankly, you really don’t want that either as you wouldn’t know if they put some spyware on your drive.
You’ll need to prep up an OS installer USB thumb drive before you swap out your drive. Here’s a good reference How to create a bootable macOS Sierra installer drive
But before you install your new SSD you’ll want to also replace the HD SATA cable as the cable your system came with is not rated for the newer faster SSD drive and often times they are work from the rough aluminum uppercase.
Here’s the part you want MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable and yes! This is a 2012 version which is the better cable! And here’s the guide you’ll need to follow MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement. I do recommend you place a strip of electricians tape on the uppercase where the cable crosses over and you don’t want to crease the cable with sharp corners! Instead you want a smooth arc, use a bamboo skewer or a ballpoint pen ink straw to form the radius of the folds.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable Изображение
Продукт
$34.99
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Great thanks for the answer! Now do I need to buy the cable with or without the bracket?
из
Either way, the short ribbon cable is fragile so getting it with the bracket is safer but a few bucks more.
из
Ok perfect thanks!
из
Depends on the seller. You can request it or if they’re a good seller they’ll do it automatically. If its IFIXIT’s SSD than yes they come with the latest software.
Оценка 0
1 Комментарий:
@ianshalongo - iFixit's SSD's are not loaded with the OS. Legally they can't sell it that way.
из
Добавьте свой ответ
Daniel Marsh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 162
