Смартфон был выпущен 22 сентября 2017 года в двух модификациях: A1864, A1897, доступный GSM или CDMA модулями. Встроенное хранилище есть на 64 Гб или на 256. iPhone 8 Plus увидел свет в трех оттенках корпуса: золотом, серебристом и Space Gray.
Why is my touch screen unresponsive?
I currently have a iPhone 8 Plus, After recently updating to IOS 12 my touch screen has become completely unresponsive, I’ve swapped the screen before due to it being damaged although it worked fine once I swapped it since I’ve updated though I’ve had nothing but issues, Could this be a hardware issue? I don’t think it’s software as I’ve tried restoring about 4 times all with the same problem.
any suggestions would be appreciated
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
The first thing that you will want to do is of course physically check your touch screen for any signs of damage. Check to make sure that it is clean, and that there's no dirt or oils that could be interfering with touch. Also check that there's no apparent water damage.
You can perform a hard reboot which is an easy but helpful method. This can fix a wide variety of issues.
You can also try a factory reset. Before you reset, make sure to back up your data either using iTunes, iCloud, or a third-party app
If it is a hardware issue, you will have to contact Apple and possibly have your screen replaced.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
I’ve tried both the soft and hard resets, Cleaned the screen, The screen wasn’t replaced by Apple before so probably won’t be touched this time
из
It maybe a hardware issue, you may go to local repair house to check and spot the problem, thanks!
из
Добавьте свой ответ
g.breslin91 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 1,501
