Charging paused. Battery temperature too low.
Hi friends i’m not asking anything i just wanted to drop this solution here bc a lot of Samsung J320F/FN that came to me for repair has this problem. If you see this error and the voltage at the battery port is 4.1 then you have to remove or replace the C1055 and the error will go away every time.
Это хороший вопрос?
This post will get lost here. If you could post a quick repair guide that would help out a lot more!
из Paul Vert
Ok i will do one
из Adrian Zymeri
