Whooping sound. Is this repairable?
When powered on, the unit emits high pitched whooping sounds (see video). I opened it up, hoping to see something obvious, but everything seems fine for a 25yo device. It does this both on battery and on Wall plug. Suggestions?
I don't have access to an oscilloscope, just a soldering iron, multimeter and limited understanding.
Это хороший вопрос?
5 Комментариев
Try the multimeter on the speaker cones or output, and see if the voltage output fluctuates.
из Jessica Parnelli Fawkes
Thanks for the reply. I tried it and saw that it indeed fluctuates. My meter is digital, so exactly how much is hard to say, but I saw over 6V values. What does this mean?
из Okeribok
Maybe a damaged amp circuit? It could be thinking there's a signal, and amplifies to max, then resets. Or maybe interference from another device?
Yes, that sounds about right. there appears to be done sounds, but that gets mangled and only one channel works. Could it be a capacitor or something? Like replace one component and it works again? Is there a way to test components without removing them? There are no visual effects (leaks, discolouration, smells)
из Okeribok
You can add some ferrite beads to the wiring. May not fix it, but it should help prevent interference.
