Четвертое поколение iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. Версия GSM; 8, 16 или 32 ГБ памяти; модель A1332; в Черном или Белом цвете.
iPhone in boot loop when charging
Hey!
So my Iphone 4 fell in water and now it is in boot loop. It actually doesn’t work without charging and when plugged into charge, it starts to boot loop. I don’t need the phone, but I have a lot of old pictures of my children in it. I tried Itunes update( I can get it in itunes mode) and all the popular programs that recover files or flash the Iphone with keeping the files. I tried the home button and power button techniques but nothing seems to work.
Can someone tell me what actually the problem is?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
its probably because of a loose battery connection if its just rebooting whilst plugged as to boot a battery must be plugged in so take the back off and check the connection
search battery replacement for iPhone 4 or 4s in ifixit and it should pop up its fairly simple all you need is a 1.5 Philips i believe
Был ли этот ответ полезен?
Счет 0
1 Комментарий:
Thank you for your answer! And is there no possibility to get the pictures that are in the Iphone?
из
Добавьте свой ответ
Jeck Hollaus буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 300
