Samsung's tenth flagship Galaxy phone, released in March of 2019. Shipped with Android 9.0 (Pie).
71вопросов Показать все
Вопрос закрыт
How to recover deleted photos from Samsung Galaxy S10
How to recover deleted photos from Samsung Galaxy S10? Is there any workable tool to do the recovery? Many pictures are gone, can I recover them?
Это хороший вопрос?
Оценка 3
Добавить комментарий
9 Ответов
Наиболее полезный ответ
To recover deleted photos from Samsung Galaxy S10, first make sure there is a backup of the deleted photos. If no, you can use Android data recovery to help you get them back. But before that, you need to make sure the deleted photos not being overwritten by new data.
Был ли этот ответ полезен?
Оценка 3
You need to check if your deleted photos have been overwritten by new files.If not,Samsung data recovery recover them easily.If it has been overwritten,it can’t be overwritten.
Оценка 2
I think this answer can help you: How to Check Recently deleted photos from Samsung Galaxy S9 +
Оценка 0
Hello, if you didn’t write new data on your phone, you can download a third party tool, I recommend the Bitwar Data Recovery, it’s free and can recover many kinds of files in Android and PC. You can have a try, hope it can help you
Оценка 0
Using Wondershare Recoverit can make you be capable to find out all your lost pictures. The best thing about this tool is that you can gain data from any device including iPhone, Android, iPad etc. you have to follow few steps to make this device starts it operation and you will see after a few minutes all your deleted data will pop up so you could be able to save it back wherever you want. Follow this link https://www.youtube.com/watch?v=W72j-h4u... to explore a lot more.
Оценка 0
Actually, it all depends on luck, even though it is possible to recover the deleted files from Android in theory.
This is because you may save new items after deletion, thus, the deleted files may be occupied and become unrecoverable.
So, do not add new data after deletion. And then, use a recovery tool to rescue the deleted photos. If you are not familiar with such process, refer to this tutorial: https://www.minitool.com/android-recover...
Оценка 0
To recover deleted photos from Samsung Galaxy S10, you can first to check whether the deleted photos are in “Recently Delete“ or not. If you have backed up your phone in advance, you can also restore the photos from Samsung backup. But if you did not back up your Samsung or you have emptied the “Recently Delete“, you need a third party, such as Bitwar Data Recovery, to retrieve the deleted photos.
Оценка 0
If you have taken backup of your pictures on Google account or Samsung backup then, you can restore from the backup. In case, if you doesn’t get back your photos from backup then, you can retrieve pictures by using any Android recovery tool on your computer.
Оценка 0
Using systweak photo recovery app, you can retrieve your lost and deleted photos form android phone.
Оценка 0
1 Комментарий:
Benim de s10 um vardı cihaza şu girdi ve bi kaç gün kulanamadim sorna fareyle açıp kapatım sorna cihaz düzeldi 5 6 ay sorna bi anda ekran kapandı açılmadı ve öyle duruyo 1 kaç kişiye sordum anakartı degiştirirler dedi bende dedim belge felan var ve o şekilde cihaz duruyo ne olmuştur ve ne yapmam gerekiyo
из
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 30,907
