Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2690вопросов Показать все
Any tips on getting the hex nut out of the phone?
How do I get this hex nut out. My bit just keeps spinning over it
Это хороший вопрос?
Оценка 0
3 Комментариев
Try a smaller bit.
из
Already did. Didn’t work
из
Not sure if iFixit sells it, I'm sure they do, but there's actually a bit that is shapped like a hexigon, I have a screwdriver that's H2.5 (Hexigon 2.5mm) and it's a perfect fit.
из
Добавить комментарий
3 Ответов
Наиболее полезный ответ
Use one that’s about the same size, but is slightly smaller and still fits over normally. This usually works to deal with stubborn ones.
If you’re finding it’s still being stubborn, you will need a driver with more torque. The issue is it was tightened more then it should when the phone was assembled at the factory. This isn't the end of the world but you will need to match the force used to have a chance at removal.
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
I did and it didn’t work
из
If you have that H2.5mm then you can try to put like a thin rubberband over the screw itself, and see if that adds into the empty space making your bit spin around it to add some grip to the twist.
из
Thr rubber band thing has never worked for me @neos_hle. What usually does is a slightly larger (or smaller) screwdriver to help fit the hole better.
That said plyers are likely to damage the board beyond repair, so it's the only viable option for getting this out as a last resort.
из
What that screw is is a stand off screw. Since its not a common screw driver at all, use a very small flathead screw driver. If it helps please give this answer a like, it would be much appreciated!!!!
Оценка 0
Оценка 0
1 Комментарий:
Добавьте свой ответ
Owen Baker будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 9
За всё время: 512
