Seeking Hot Water Release Tab
Cuisinart does not carry this part (to my astonishment and disbelief). It is basically a soft plug that goes in the bottom of the unit. You pull it out to drain the water reservoir and push it back in to seal. Mine got lost during a cleaning. I can’t make hot tea without it. Otherwise, the unit works fine.
Это хороший вопрос?
Оценка
0
Hi @dmgfa ,
Don't know your machine but if you post some close up images of the drain hole and perhaps give some measurements someone may come up with a workable solution. Maybe visit a plumbing supply store and check if there are any suitable plugs that will do the job or perhaps a suitably shaped wine bottle cork may be good enough to serve as a bung in the drain hole. Just some thoughts.
Here's how to do this.
Adding images to an existing question
из jayeff
