Announced on October 16, 2014, identifiable by the model number A1347 and EMC 2840.
197вопросов Показать все
Fusion Drive has died. What was the best recommended replacement?
My Mac Mini was taking forever to boot up and would not respond once booted. I found out in recovery mode that it has severe SMART issues on the Fusion drive.
I need some advice on what should be the best replacement option. I am thinking if it is the HDD, replace it with a SSD of similar size or larger and go from there, or just replace the SSD, if it is bad.
From what I’ve read so far, replacing the HDD is not a huge improvement, but I’d like to increase the size from 1TB to possibly 1.5 or 2 TB.
Это хороший вопрос?
Оценка 0
3 Комментариев:
What sizes are your current drives?
Please insert your serial number on this link and tell us your exact machine:
https://everymac.com/ultimate-mac-lookup...
из
1tb hdd and 128 gb ssd.
из
Which drive are you seeing the SMART errors the HDD or the SSD?
What is your systems specs model or year?
из
Добавить комментарий
1 ответ
Your SSD is much smaller than your HDD. I’m going to guess your HDD is failing.
Replacing it with a new drive. I would recommend going with a hybrid drive (SSHD) like a 2.5” Seagate FireCuda. Or, if you want go with a 2.5” SSD but its going to be more expensive than a HDD or a SSDH drive Mac mini Late 2014 Hard Drive Replacement
You’ll first need to break the Fusion Drive set following this guide first How to split up a Fusion Drive.
I would remove the blade SSD as its so small its quite useless. If you want some real performance you’ll want to upgrade it to a larger drive and make it your boot drive. Here’s a good reference on these drives The Ultimate Guide to Apple’s Proprietary SSDs and here’s the guide Mac mini Late 2014 SSD Replacement
Using a 128 GB or 256 GB blade drive will offer a huge perforce gain and then you can have the HDD for your deep storage. This is the best long config gaining the best of a dual drive (not a Fusion Drive).
Mac mini Late 2014 SSD Изображение
Инструкция
Сложность:
Модерировать
15 minutes
Mac mini Late 2014 Hard Drive Изображение
Инструкция
Сложность:
Модерировать
30 minutes - 2 hours
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Avery Reddick будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 302
