GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152вопросов Показать все
should I replace the LCD or the digitizer alone?
the case is that , the imaging of the iPad is perfectly fine, but I have this difficulty in touching when touching certain parts of the screen (ex. when I am typing a message, at some point, the point where letter A, and N located isn’t functioning at all.. i need to rotate the screen for me to type the letter A and N..) should I replace the LCD ? OR IS it ok if I only replace touch pad or digitizer? pls do give me some advice
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
The digitizer has two layers which is touch screen and glass. Replacing that part will fix the touch problem.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
French Marie Escabarte будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 55
