Repair and disassembly guides for Kenmore Microwaves.
182вопросов Показать все
Microwave shuts off intermittently, already replaced door switch assem
I have a model 401.80082700 serial 725MM00044. Intermittent problem. Microwave goes through heating cycle and then totally powers off…no display, no light, no power. After 15-30 seconds the display comes on and instructs to press clock and reset time of day. After doing so the microwave is fully functional and may operate several times before powering off again. Occasionally the display appears fainter than normal, esp the center of display. I have replaced the door switch assembly but after several days the intermittent problem has returned. What do you think? TY
Это хороший вопрос?
Оценка 3
1 Комментарий
After much delay and frustration I ordered and replaced the control board…..works great…..thanks for your recommendation!
из
Добавить комментарий
2 Ответов
Выбранное решение
Sounds like the problem is the control board, not the door assembly. Try replacing the main controller circuit.
Good luck!
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
I have the same problem with my Kenmore microwave. Is this the part I need? https://www.searspartsdirect.com/product...
из
Наиболее полезный ответ
There are two parts to that door switch, here they are on your model along with how to test them:
https://www.repairclinic.com/RepairHelp/...
Оценка 2
Добавьте свой ответ
Ken Thome будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 1,035
