Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
1364вопросов Показать все
Can I replace my charging port since it is not charging now?
I have an iPhone 7 plus that does not charge. I faced this problem a couple of months back too. I went and had it repaired in a repair shop and they told something that i could not understand. They also said that my phone damaged a couple of their flex too. I donot know what they were talking about and other thing is that the phone would charge if the lightning connector was connected on one side only. Meaning that the other side of the lightning connector wouldnot charge my phone. It worked on both sides till now though so i was hoping if replacing the charging port could solve my problem. HELP!!!!!!!!!!!
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
It’s unfortunate that you don’t remember or understood what the shop told you because it was certainly important. If you feel like you are being bamboozled, ask them to explain it again…it’s usually important.
Yes, you can replace the charge port but based on the history of the device and the symptoms it exhibits, I would suspect something may be wrong with the charge circuit on the logic board. Of course, the first step in diagnosing this correctly is to try a replacement charge port. If you do it yourself, you will have to buy the part upfront. Another option is to find a reputable shop that does micro-soldering as they will be able to dig a little deeper.
Был ли этот ответ полезен?
Оценка 3
yes you can. iPhone 7 Plus Lightning Connector Assembly Replacement
Оценка 0
Добавьте свой ответ
Arun Rai будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 84
