The ZTE Blade Spark is a prepaid AT&T device released in July of 2017 and can be identified by the model number: Z971
12вопросов Показать все
Dead phone/ USB c female broke
The USB port completely came out. Phone belongs to my better half. I got him a S7 and jus need enough juice to retrieve some data. I've disassemble the phone for the most part. I'm a noob and jus looking for some insight on which way to go. Should I try to connect to battery? If so how do I get to the positive and negative terminals?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
I checked this battery model on Google and i don’t think that is a good idea to give some juice by connecting positive and negative terminals. I mean,there’s components on your motherboard that will control the voltage and Amp to charge the battery in the right way. The thing is a little bit more complex then just conect negative and positive wires.
If you have a DC power supply is a different story,you could use it to power up your phone and retrieve your data.
If you have a universal battery charger you could use it to charge your battery by connecting positive and negative.
Here’s an exemple of a universal battery charger : https://www.amazon.in/Rebel-Universal-Mo...
Hope that helps.
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
I sure will look for power supply and give it a try. Tysm
из
Добавьте свой ответ
Kimberly Brrtrand будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 138
