S8 новейший флагманский смартфон компании Samsung, представленный на Unpacked 2017 в апреле.
Mobile Network Not available
I have a circle with a line through it where there should be cellular signal strength. Have tried all the “ususal suspects”, multiple network resets, wifi calling is off, reset phone to factory defaults and even full factory reset and reload software. Tried multiple sim cards, all of which work in other phones. Phone is now apart…..all parts look in tact and fully functional. Phone seems to recognize when I install a sim card, but never gives a connection to a network. From phone firing up after complete system restore, the circle with the line is present. Any ideas?
Это хороший вопрос?
Счет 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
If the phone is use, maybe is Black Listed in USA Networks, or has a wrong Sim Card.
If was working fine and stopped working, Base Band Chip may have issues, Check if you can see the IMEI Number in your Settings.
If you dropped recently may has a Internal Antenna Disconnection.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
dougal буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 14
За всё время: 1,058
