Face ID is not available after drop
Hello
i have a problem regarding the Face ID of the iPhone XS Max. After dropping my phone on it’s back the glass on the back shattered.
But unfortunately since then the Face ID also doesn’t work anymore despite the fact that the front panel is in perfect condition.
The portrait mode with the front camera doesn’t work too. It doesn’t recognize my face properly.
my question is: Which part has a failure and how can I manage to bring the Face ID back to life again.
Это хороший вопрос?
1 Комментарий
Unfortunately FaceID technology is based upon a variety of sensors which are very fragile and will very easily break once the phone is dropped (especially dot projector), this is why humidity and moderate bumps will often results in faceid PERMANENTLY broken. And since Apple products are built to trap the user in their ecosystem made by reckless and lucrative rules, you won't be able to fix it unless you spend an insane amount of money in Applecare services or individual repair. In this specific case, changing the damaged part only is not going to fix the issue because it's paired with the main board, it's the trick they use to maximize profits on poor ignare people that buy their products. A sort of legalized scam.
The best thing you can do is always avoid to buy Apple products and in 99% cases you will be able to fix your phone at cheap.
из GIGGI'
