Выпущенный 16 сентября 2016 года смартфон нарекли iPhone 7 Plus. Вышло несколько моделей нового устройства: A1661, A1784, и A1785, а также можно было выбрать между версиями на 32, 128 и 256 Гб встроенного накопителя. На выбор можно было приобрести золотой, розовое золото, серебристый, Jet Black и (PRODUCT) Red оттенки корпусов.
1364вопросов Показать все
Can you still use home button after replacing Logic Board?
I recently tried to do a mini jumper fix on an iphone 7 plus Logic board. This was to fix the slow boot and audio problems that the 7 plus is renowned for having.
I had a lot o trouble removing the old chip and subsequently damaged it. I also pulled a bunch of pads off the board.
I see plenty of posts about changing the home button and that the itouch won’t work anymoe.
What I need to know is that if I purchase another leaderboard, can I still use the original
home button as a button without using touch ID?
Это хороший вопрос?
Оценка 0
1 Комментарий
I was looking on Ebay and saw an ad for iphone 7 plus home buttons. It had this posted in the description.
“Please note that only the original home button assembly will be capable of using the Touch ID functionality.
Installing a new home button will only restore ordinary home button functions, not the Touch ID features. “
I’m really not fussed about using the Touch ID functions, but would like to use the home button.
Does this sound right?
из
Добавить комментарий
2 Ответов
Выбранное решение
You won’t be able to use at all the original home button on an iPhone 7 unless the board you’re buying will be supplied with its original home button. What you can find in the market now are bluetooth buttons that can be installed with a small mod and then paired with the bluetooth assistant.
I bought a couple to try out and the first I installed broke in no time with the top glass part partly detached from the button housing..opened it up and saw the build is pretty primitive and unreliable. I managed to fix it with a tiny bit of biadhesive but it took extra time and work and the clicking is a bit stiffer now. That’s all I can report about it..it works but the making should be improved. Clever idea though :)
Был ли этот ответ полезен?
Оценка 3
6 Комментариев:
Well there are 3 variants out there. Here is starting from worst to best (top to bottom):
- JC Home button: First iteration V1 of the bluetooth home button. Required jumper pads and paired via bluetooth.
- HX home button: Second iteration V2 of the bluetooth home button. No jumpers required, still pairs via home button.
- YF home button: Pretty much the best you can get. Taptic feedback, no jumpers required and no bluetooth pairing required. It just works seamlessly.
JC is like $10 home button, HX around $20, YF is pricey at the moment as it's new $40.
Edit: YF is currently unstable it has reported to have caused screens to short circuit and phones to get stuck on apple logo.
из
Great info @benjamen50 . I believe I had no other choice than JC at time of purchase, so that's the one I was reporting about. Further iterations seem to be nicer evolutions, I hope the build quality is better and made to last too. Thanks!
из
Just updated my post to warn that YF which is also known as (Version 6 on some websites) is unstable atm.
из
@benjamen50 Thanks for the warning, will keep an eye out for further news before purchase. Shorts to screens and stuck phones, even if limited, are pretty bad troubles to deal with.
из
we ordered several of the YF versions and confirm they are just as terrible as the rest. yes, they "work" for a while, then cause black screens randomly, at least one reboot, and at times seems to be slow to respond. while i will agree this is the best of the current solutions, it still has a ton of problems and they are unusable as a solution that we feel good about sending out to and end user.
unless you are just desperate, stay away.
из
Показать 1 больше комментариев
You have to use the home button that comes with new logic board. You can’t exchange home buttons. That’s you can’t use the home button from the old logic on the new one
Оценка 0
Добавьте свой ответ
Terry будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 1,305
