Repair information and guides for the long-awaited refresh of the popular MacBook Air, featuring Intel's Core i5 processors, an updated Retina Display, and numerous other changes and updates that was released on November 7th, 2018.
150вопросов Показать все
4 % battery loss after 22 cycles
Hi,
I bought my MacBook Air 13” Retina 2018 almost 2 months ago, and have now a total of 22 cycles. I always let it decharge to <20% before I recharge it to 100% and then unplug it - trying to have preserve the battery life as good as possible. But after just 22 cycles I have lost almost 4 % health.
Is it normal for the battery to loose a lot on the first cycles, or does this indicate a bad battery? Apple says its suppose to have 80 % left after 1000 cycles, but at this rate I will have 80 % at 100 cycles, or is this method of calculation far off?
I’m soon going to have the top case replaced because of a bad Butterfly keyboard, and should I then also complain about my battery? Or is my situation normal?
Это хороший вопрос?
Оценка 0
2 Комментариев
How about running CoconutBattery and posting a snapshot so we can see its health Adding images to an existing question
из
I have now uploaded the photo, but I don't think I says anything more than the text - as the info in the post is based on coconut.
из
Добавить комментарий
1 ответ
Выбранное решение
Actually it’s not as bad as you may assume. I get a lot of new batteries and I’d my average for a new one is about 95%. So I would keep an eye on it for a while and see if it continues dropping at the current rate before sweating it to much.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Miksen P будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 82
