Дата выхода 19 сентября 2014 года. Это маленькая версия iPhone 6 Plus с 4.7-дюймовым экраном.
4994вопросов Показать все
Phone exhibiting odd power drain issue. Too many cycles?
A friend of mine upgraded his phone and is giving his old iPhone 6 to his kid, so he asked me to clean it up and check it out. I replaced the battery in this phone with a quality aftermarket battery a bit less than a year ago. CoconutBattery reads the battery at 89.5% of its design capacity (1620/1810 mAh) with 666 cycles (yeah, really) which I think is a bit high for a <1 year old battery.
Phone came to me about 65% charged so I connected it to the charger. It fully charged to 100% and the back of the phone was very warm (slightly uncomfortable to hold for an extended period of time). I performed a factory restore on it and let it sit (unplugged). About 17 hours later the battery was still at 100%. Eight hours after that (25 hours after being fully charged) it was at 99% so I figured the battery was good.
39 hours later (64 hours after being fully charged) I found the phone *completely* dead/discharged. Remember, the phone was doing nothing; it was still at the “Hello” screen after the factory restore and was untouched the entire time. I thought it very odd that it would drop 1% in 25 hours but then completely discharge 39 hours later.
Right now I’m thinking it’s just a worn-out battery, but CoconutBattery is reporting it at 89.5% capacity which would indicate it still has life in it. I’ve seen phones with less than 80% capacity sit idle for longer than 39 hours. I’ve put in a new battery which is now charging; it’s drawing 1.2-1.3 amps and the phone is not warm at all. The old battery is not swollen or otherwise visibly damaged.
Am I on the right track here, thinking it’s just a worn battery?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Yup, I’ve had aftermarket batteries go bad to where they suddenly start draining fast after a year or so equivalent of use.
I would test it again just in case it’s not the battery. If the same symptoms don’t persist then the phone should be all good to go.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Steve будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 37
