High Temperature / High Fan speeds
Hello everyone!
I have acquired a 2010 MacBook Pro and it has a really bad overheating problem.
Is it supposed to get really hot? Is it because of the old CPU and GPU and they just run hot?
I replaced the thermal paste and it still gets hot with slightly better thermals. I wanted to try and see if liquid metal would be an option although I’m not sure if the heat sink is copper or aluminum since I know it will happily eat away at it in a matter of hours.
Any suggestions?
Thanks!
Edit: Here are the screenshots. I hope they help
Это хороший вопрос?
4 Комментариев
How about getting a better view of the systems thermals. Install this app TG Pro. Take a snapshot of the main window (you may need to grow the window so all of the sensors and fans are visible) while idling and a second once you have it working for a good day so we can see the high water marks. Post both here for us to see Adding images to an existing question
Don't use Liquid Metal! It won't help you here! Once we see what's happening we can guide you on whats needed.
из Dan
Alright ill try that and put a snapshot on. Thanks Dan
из Corey Meyer
@activoid - It does look like your heatsink has failed! Review @mayer answer below.
из Dan
I took it apart once again and didn't find any stains. However I did find that when I last replaced the thermal paste it was a sloppy job and I probably didn't put enough on it. As of me typing this I am averaging at around 140 *F. But ill try to use the computer throughout the day doing normal everyday taks and see if it will stay below 100 *C
из Corey Meyer
