The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623вопросов Показать все
MacBook Air Not Powering on but charging
Mac’s fan hit higher rpms and got stuck. Hence I closed the lid and opened and then also it got stuck while typing password. After that I closed the lid again and it is not powering on from then on. I have done SMC reset by pressing SHIFT CONTROL OPTION + Power and noticed the charger showing a momentary green light after releasing the buttons. Even then, it is not powering up. Can I get an help from experts?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Sounds like a liquid damaged keyboard, is the magsafe charger light always switching to green momentarily when you hit the power button and have the magsafe charger plugged in?
If yes I strongly recommend getting the MacBook inspected on the inside for signs of liquid damage / corrosion. The earlier it’s treated the better the outcome will be for liquid damage repair, sometimes if it’s not severe enough a keyboard replacement and some isopropyl alcohol cleaning with cotton buds will fix it.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
No Sir, It is not changing light always. It changes only when I press keys for SMC reset.
из
Добавьте свой ответ
Krishnakumar будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 38
