Clothes dryer repair and support guides.
871вопросов Показать все
Kenmore Dryer Model #110.96572820 Not Heating
Kenmore Dryer Model #110.96572820 Not Heating…have replace long white thermal fuse 279816, Thermostat 312968/3390291, & Cycling Thermostat 326801/3387134, & dryer still not heating. Original Thermal Fuse 279816 tested good…have a new one just haven’t replaced yet. Have not tested the heating element yet either, but found this website, so I thought I would ask!! Help!!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Cause 1
Heating Element
The heating element warms the air before it enters the dryer drum. Over time, the heating element can burn out, causing the dryer not to heat. To determine if the heating element has burned out, use a multimeter to test it for continuity. If the heating element does not have continuity, replace it.
Cause 2
Incoming Power Problem
If your dryer is not heating, then you may have an incoming power problem. Electric dryers need two legs of 120 volts AC equaling 240 volts. It is not uncommon for only one fuse or breaker to trip resulting in the dryer able to run, but not heat. The fuse box or circuit breaker should be checked or voltage measured at the outlet using a multi-meter.
Cause 3
High Limit Thermostat
The high-limit thermostat monitors the dryer temperature and shuts off the burner if the dryer overheats. If the high-limit thermostat is malfunctioning, it may shut off the burner even if the dryer is not overheating. However, this is rarely the case. Before replacing the high limit thermostat check all the more commonly defective parts. If you have determined that all of the other components are working properly, test the thermostat by using a multimeter to test it for continuity. If the thermostat does not have continuity, replace it.
Cause 4
Timer
If the dryer doesn’t heat, the timer might be defective. However, this is very rarely the case. Before replacing the timer, check all the more commonly defective parts. If you determine that all of the other components are working properly, test the timer by using a multimeter and consulting the wiring diagram. If the timer is defective, replace it.
iFixit Staff Suggestion: For additional information you can go to Electric Dryer Not Heating which addresses a few other causes as well. —Bill Gilbert
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
I second the heating element. I find that these often go bad more than the thermal fuses.
из
@tdunc15 Mine has two separate ones.I've replaced them twice in the last twenty four years. Both times only one has gone out and it increased my drying time dramatically till I fixed it.
из
@mayer, maybe it just the dryers I've worked on (mainly Samsungs and LGs). On my personal dryer, I've replaced it 3 times in the last 6 years, and have yet to replace a thermal fuse.
из
Добавьте свой ответ
SHERYL A CONARD будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 5
За последние 7 дней: 31
За последние 30 дней: 163
За всё время: 12,815
