Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203вопросов Показать все
CPU turns on, fan spins, screen flickers then black screen
Hi, I have a 2008 13” MacBook A1181 (EMC 2242, MB 820-2279-A) wich does not want to boot.
This is what’s happenning:
  • I press the power button once
  • The macbook turns on, the cpu is running and getting hot, the fan is spinning, the activity light turns on white
  • About 4 seconds later, the screen “tries” to turn on for a split second, and then the screen turns back off, meaning there is no backlight and no image (I shined a light on the screen to verify this), and the activity light turns off
  • The cpu keeps running and getting hot and the fan keeps spinning
  • Then I cannot do anything, and I have to shut down with a single press of the power button.
What I tried:
  • Resetting SMC and the NVRAM, but macbook doesn’t seem to respond to the key combinations
  • Visual inspection on both sides of the board and could see no physical damage, no corrosion
  • CPU Vcore is present, it’s reading about 0.930V
  • With the charger plugged in but no battery present, the magsafe connector shows a green light
  • With the charger plugged in and a battery present, magsafe turns green then amber, and one battery level light keeps flashing. If I disconnect the charger, about 4 seconds later the one battery level light flashes very fast around 6 times and then turns off
  • The macbook behaves no differently with or without battery, with or without keyboard, by changing the RAM combinations
  • Removing all ram DIMMs does make the motherboard put out a beeping noise
  • I plugged my phone to see if USB is working and sure enough it is charging when the macbook is turned on.
I would really like to repair this macbook if possible, and it seems to be very close to be working so I have hope I can bring it back to life.
Could anyone please give me some help to troubleshoot this? All help is very greatly appreciated.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
First let’s see if you can get that battery charged up. Leave the machine off. Hook up the mag-safe and leave it over night. In the morning press the battery test button. Please let us know your results.
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Amine Kchouk будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 113
