Выпущен в 1999 году, преемник оригинального PowerMac G3, частота 300–450 МГц, 64 или 128 МБ оперативной памяти, жесткий диск 6 или 12 ГБ
won't power on
Hello!
I am also having the same problem. I did what u suggested and nothing. I opened the computer and I noticed that 1 of the plugs P5 was not connected to anything. My question is should that part be connected and if so where? Maybe that is what is causing my G3 not to power up?
Thank you.
Edie
Это хороший вопрос?
Счет 0
1 Комментарий
Please start a new question as this one has been answered and almost no one will now look at it. Thanks
из
Добавить комментарий
1 ответ
Выбранное решение
The Plug "P5" is just another 4-Pin Molex power connector. It is used to power a secondary hard drive, and doesn't need to be connected to anything for the computer to work. If the computer isn't powering on, a bad power supply may be to blame. The PowerMac G3 Blue and White (as opposed to newer/older powermacs) uses a standard PC "ATX" power supply. You can buy these at just about any store that sells PC parts, or use an existing one if you happen to have one handy.
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
edith буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 9
За последние 30 дней: 21
За все время: 1,528
