Компания Apple представила iPhone 5c 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 8, 16 или 32 ГБ памяти; в цветах: Белый, Розовый, Жёлтый, Синий и Зелёный.
1233вопросов Показать все
Lightning to 3.5 mm cable shows "accessory not supported"
Hello everyone,
So yesterday, when i connected my headphones to my iphone 5c via the standard 3.5 mm headphone jack, but the output sound was like someone singing underwater. So today, i went and purchased a Lightning to 3.5 mm adapter and the audio plays fine for some time, then it abruptly stops and a popup shows up saying “this accessory is not supported“. What should i do?
Это хороший вопрос?
Оценка 1
Добавить комментарий
4 Ответов
Наиболее полезный ответ
Does the cable plug go fully into the socket or is there a noticeable gap between the phone and the plug?
If there is a noticeable gap the charging socket needs to be cleaned with fine tweezers, or if needed a toothpick / sim pin eject tool. Be careful of the pins at the bottom of the charging port as they can be damaged if pushed against when cleaning the port.
For the headphone jack problem. The port either needs to be replaced or the housing replaced (if it is bent right at the headphone jack. It could also be the same problem of dust build up in the headphone jack port.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Hello Ben,
I tried cleaning the charging port, but the problem still persists. After playing a song for 1 minute, It shows the message, "This accessory is not supported by this iphone". The adapter is non mfi.
из
This accessory is not supported have the bad contact of cable to connector.There is possible resion.
1-Clean the connector might be dirty.
2-Change the charging flex.
3-Charging cable itself might be problem.
4-Trister might be also problem,This need microsoldering skills.
Оценка 1
These answers are bullshit!
it’s a software issue! and the culprit is Apple Company itself! Just buy an Apple certified adapter and it will work perfectly! In short: ( the headphone adapter you used isn’t genuine!)
Оценка 1
1 Комментарий:
I have several Apple Certified adapters that no longer work as expected. I get no warning that the adapter is not working. 14.1 and newer iOS updates do not fix or have actually caused the issue. Apple needs to fix this and stop breaking its own rules. It is so infuriating to deal with Apple thinking they need to step away from industry standards.
из
No. These solutions don’t work. Apple is breaking the trust of the customers by enforcing these rules through software. If the contact is dirty or loose then how does the music play for one minute and gets cut exactly at one minute timeframe every time. Is the dirt or loose connection so smart to take effect every one minute
Оценка 1
Добавьте свой ответ
Saikiran Bait будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 22
За последние 30 дней: 55
За всё время: 6,146
