Basic Sony Laptop Computer running Windows 7, identified by model number VPCEE26FX.
4вопросов Показать все
Where is the backlight inverter located on this laptop
I want to replace the backlight inverter for model number pcg-61611L but don’t know where it is located
Это хороший вопрос?
Оценка 0
2 Комментариев:
@gollyg1 post some pictures of what you see with your question. that way we can possibly assist you. Adding images to an existing question
из
I sent 3 picture not sure if you received them. I think I did it right
из
Добавить комментарий
2 Ответов
The inverter itself is held to the back of the lid (behind the mounted screen position) by a sticky surface, probably two sided tape, given Sony's love for taping things in this model. The whole inverter unit can't weigh much more than an ounce and is easy to replace.
Check out the tutorials and you may get to know it:
https://www.fonerbooks.com/laptop_8.htm
Don’t forget to back up your computer in case any issue unexpected may happen.
Был ли этот ответ полезен?
Оценка 0
6 Комментариев:
Albert, I think this computer is lightly different from the one you posted. On this laptop when I take all the screws out and bring the monitor down, the only thing I see on the inside is a long board about 2 inches wide and pobably 14 inches long. The video cable connects to it. I know that some some inverters are about 6 or less inches that are under the bevel in the center but there is nothing there on this compute. If there is a way I could send you a picture of it.
Thank you for trying to help me, I really appreciate it. I like helping people as well.
God bless.
из
Hi Reatha,
Sorry it is not of help, but you'll be greatly appreciated if you would like to share a picture of your laptop, you may upload and share me the url, I'll be trying to help you. thank you!
из
I was told to post a picture by ol turkey, I tried to post them with the instructions he gave. I don't know if they went through but I am trying to repair this computer. I accidentally erased "If you don't want these emails anymore, click here to unfollow this topic," in my email. Hope to hear from you. Thanks, Reatha
из
@gollyg1 Hi Reatha, you may just edit the question and add the pictures so that all of us can see them, thank you!
из
Hi,
Did you get the 3 pictures that I posted about the backlight inverter?
Hoping to hear from someone soon.
Thank you.
из
Показать 1 больше комментариев
I have the same issue. Where is this %#*@ inveter? What if replace the hole screen?
Оценка 0
Добавьте свой ответ
Reatha Gibbs будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 8
За всё время: 553
