Device name is Jensen 3 speed stereo turntable. Model is JTA-230.
9вопросов Показать все
Why won’t regular headphones and earbuds fit in the headphone jack
We recently purchased this model turntable specifically because it has the built-in headphone jack. However, regular headphones/earbuds won’t fit the jack. Do I need to buy an adapter or return it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@sharpmom teh Jensen JTA-230 uses a 3.5mm headphone jack which is pretty much standard for headphones. The question now is what size is the connector on your headphones/earbuds. Measure the diameter of your connector and let us know what it is. Or post some images with a measuring tape next to it so we can see what you are dealing with. It is not the JTA that is unusual. If nothing else maybe you have a make and model for your headphones/earbuds Adding images to an existing question
Был ли этот ответ полезен?
Оценка 1
Buy an adapter. That is the first thing I would try.
Оценка 0
Добавьте свой ответ
Christine Sharp будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 9
За всё время: 71
