Random black screen, sometimes with flashing lines
So I've searched and searched… Looking for an answer
I recently bought a 13” MacBook Air Mid 2011.
Most of the time when booting, it gives me a black screen (no image, no backlight). Sometimes the screen and backlight work on boot.
Usually have to do the NVRAM reset. Now, when I close the lid and reopen it, most of the time it is just a black screen with backlight glowing a bit. I can usually close and open it about 6 or 7 times with just backlight and no image before I open it and then I have image and backlight in perfect quality.
Some of those times when I open it, I'll have a quick set of whitish gray lines that flash briefly. These lines are completely random how they flash and located.
I'm wondering if this is the LVDS cable or a logic board issue.
Update (07/11/2019)
Ok. I guess my final question would be, can you just buy that chip and have a professional install it to the board or would have to go the entire logic board route? If I have to go the logic board route, is it worth spending 150 bucks on a board? I bought the laptop for 80 bucks.
Update (07/11/2019)
Any way of spotting board version differences?
Update (07/18/2019)
So got a new board in and have the initial startup sound but nothing else. No image and no backlight. What is going on now? I pretty much 100 percent guarantee that nothing got broken on install as I'm very careful.
Ok. Strike that. Board appears defective. Seller is taking it back. Dan, what parts houses are you referring to?
Also, is it worth upgrading to the 1.8Ghz i7 board or not?
Update (07/22/2019)
So here's a question, since it successfully boots every time with backlight without new logic board, but has that issue when closing the screen, is there a terminal command or something that can force the screen to remain on even with lid closed?
Update (07/26/2019)
So it's not the logic board. I have purchased one online and it is doing the exact same thing. Any other ideas.
Это хороший вопрос?
4 Комментариев
Sadly, Intel no longer sells the needed chip and hunting down a virgin chip will be hard. Even still you could get a salvaged chip from Amazon or eBay which is no better than yours! Risky endeavor.
I would recommend sticking with the board swap out if you want to continue using this system.
Consider the limitations and lifespan if you repair this system Vs getting a new system.
из DanJ
Since I paid so little for this laptop, I went ahead and bought a new logic board (well fully functioning logic board). We will see if this fixes my problem with this laptop. Thanks for all of the help and I will post the update, once it is installed.
из Brett
Sorry I don't know of any way to do that. Idon't think you want to do that either as you'll cook the display
из DanJ
Sorry missed your question. I find either of these folks are good suppliers:
● TheBookYard UK - MacBook Air 13" Logic Boards
● BeetsTech US - MacBook Air 13" Logic Boards
из DanJ
