12 Volt power spike on USB
I am positive that one of my USB ports was spiked with 12 volts.
Now i cant get any power from the two front ports.
If i plug in a device with external power, the device will communicate properly.
I tested the ports thoroughly.
And i have come to the conclusion that the Vcc is disabled now or a component blew.
Any advice would be great.
Это хороший вопрос?
2 Комментариев
i did disable "Allow the computer to turn off this device to save power" on all 3 Root Hubs
no change
из Tyler S
I think it is a component on the vcc pin of the usb ports blew because data still works as long as the device plugged in has external power. So i am 100% sure the vcc pin is the problem.
из Tyler S
