Is building MacBook myself cheaper, than buying from apple?
Is building macbook myself cheaper, than buying from apple?
Это хороший вопрос?
Это хороший вопрос?
Another good option is a used one with cosmetic challenges, but is perfectly functional otherwise. If you can find one with cosmetics you can live with and the price matches the actual damage (everyone has a different tolerance here), you can generally get these at a descent discount. I got a 2011 13” MBP through this method and it was better then I expected it to be relative to what I paid.
Just so you have a good baseline, here’s mine. Tweak it as you need:
Don’t expect a massive discount on an 8GB Air (which you want since the RAM is soldered), but if all you have on it is a few barely visible dents and some scratches, I’d say take the discount if the machine is within your tolerance range. They’re harder to sell, so you can do pretty good with a cosmetic issues machine with acceptable damage.
This is what I personally consider acceptable. I don’t deal with massive dents and unibody/bottom cover damage because that was abused:
Был ли этот ответ полезен?
It’s according to what kind of hot rod you want built! Sure you can build this one up to compete with the latest thing Apple has out. And it’s repairable with reasonably priced parts!
Apple MacBook Pro "Core i7" 2.9 13" Mid-2012 Specs
Identifiers: Mid-2012 13" - MD102LL/A - MacBookPro9,2 - A1278 - 2554*
Apple MacBook Pro "Core i7" 2.6 15" Mid-2012 Specs
Identifiers: Mid-2012 15" - MD104LL/A - MacBookPro9,1 - A1286 - 2556*
It depends! Finding a bunch of broken systems which you can merge into a working system is possible. But you tend to end up needing some parts which could cost you the difference.
I would recommend you just look for a used system (working) as the first option. If you want something newer then you’ll need to buy a refurbished one or new from Apple.
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 141
