Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597вопросов Показать все
Password not working when unlocking
I set my laptop password as 4 numbers. When I use the MacBook keyboard to type said 4 numbers, the laptop doesn’t accept them even though the numbers are correctly typed. When I use a mechanical USB keyboard, the same thing occurs. However, on the USB keyboard if I use the numpad on the right side of it, then for some reason it accepts the password. I have checked if the keys work, and the keys all type correctly.
I changed my password to QWER, and it wouldn’t accept it even thought I typed the password correctly into the login page.
Это хороший вопрос?
Оценка 0
2 Комментариев
Are you seeing a lock icon on the screen or are you seeing a User login screen for a given user account?
Reference: About the screens your Mac displays as it starts up
из
It lets me choose the hard drive to boot into, then once I choose it, a grey background shows and my name asking for the password.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Probably the keyboard layout on the password screen is wrong, such as used non-US keyboards and resulted in different key mappings.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thanks for the answer, I made sure when I changed the password, it’s on Britain PC and when I type the password on the login screen, it is also on Britain PC
из
I would try using a USB or Bluetooth keyboard to isolate out if the built-in keyboard is not working correctly.
Оценка 0
1 Комментарий:
Yh the keyboard is bit dodgy, but the numbers for the password on the keyboard all work. When I use the keyboard on google chrome for example, the numbers work and the correct numbers are entered. Also, when I turn my Mac from sleep, the in built keyboard works to unlock it, it only doesn’t work when I boot the laptop from shutdown
из
Добавьте свой ответ
Hamza Zaman будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 159
