Repair guides and support for wireless and wired Apple keyboards.
209вопросов Показать все
Key S will not work
I have a apple keyboard Model A1243 and have been using it for my PC that I have in my room. However the S key has stopped working as everything else still works. I have tried cleaning it out but still does not work. Is there a way to fix it?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
If you have popped off the key cap and cleaned in there., and then tried to simply press on the silicone bump and you still get no response, there is no fix…the circuit has most likely “died”.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
taylordrain будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 38
