Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203вопросов Показать все
Why won’t my Nintendo 2DS XL turn on?
Recently, my 2ds xl will not turn on no matter what I do! Just a Week ago it was working perfectly now it won’t turn on? If anyone can give me some advice that pI duo be greatly appreciated :) thank you.(also even if I charge it no lights flash it just won’t turn on
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
@hobi_j check your charger to make sure that it is working. After that check the charging port to make sure that it works and check/replace your battery. That way you have a known well starting point for further troubleshooting. If all of those parts are functioning you will have to disassemble your 2ds xl and check for any obvious damaged components on its motherboard. Post some good pictures of that with your question so that we can see what you see. Adding images to an existing question and here is the teardown Nintendo 2DS XL Teardown
iFixit Изображение
Инструкция
Сложность:
Очень просто
2 - 5 minutes
New Nintendo 2DS XL Изображение
Инструкция
Сложность:
Модерировать
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
Uh yeah ok. I am currently not at home where my 2ds xl is but once I arrive I will be able to show some photos of it. Also I will be getting a new cable to see if that works since I have been using the same cable I
Got from my dsi in 2012. (I think I may have lost my 2ds xl charger I don’t know)
из
Добавьте свой ответ
Joel Serrano будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 143
