Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1192вопросов Показать все
No network at all in my F5-573G-771D
All of a sudden my Aspire F15 lost WiFi connection.
The weirdest thing is that the network icon doesn't show up at the bar anymore.
I've gone through all the basics
  • Wireless is active
  • Tried an usb TP-Link ac1900 successfully installed, notebook cannot see any networks
  • Ethernet cable directly connected to the router unsuccessful
When I try to find wireless networks I receive a message that my computer cannot be seen
Any advices?
Это хороший вопрос?
Оценка 0
1 Комментарий:
Hi @andrebertrand ,
When you say all the basics does this include the following as you didn't mention the result if you did.
Did you check the status of the WLAN network adapter in Device Manager?
Did you try the Network Troubleshooter in Control Panel > Network and Sharing Centre > Troubleshoot problems?
из
Добавить комментарий
1 ответ
Right click on start menu icon then go to “Device Manager”, search for “Network adapters” and tell us what you see, in normal case it should be something like that
If you notice an exclamation mark in the icons then try to troubleshoot it.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
ANDRE BERTRAND CAVALCANTI будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 115
