The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
Can you install a blank SSD if your old SSD has failed?
So my old SSD failed so I need to put a new one in.
I don’t care to have a backup, I just want to start new so can I put the new blank SSD in the system and download the OS over WiFi directly without an external hard drive?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
Thanks for asking Luke! If you don’t need any data swapped then you should be able to install a new ssd into the device and use internet recovery to reinstall Mac OS by pressing the command key + R at the same time but keep in mind that these devices use a proprietary connector and it’s not a normal m.2 or sata connection.
Best regards
-Activoid
Был ли этот ответ полезен?
Оценка 2
3 Комментариев:
So I can just put the new one in then where the old one was right and it should work so I shouldn’t need any connections?
из
Yes, Refer to this guide on ifixit MacBook Pro 13" Retina Display Early 2015 SSD Replacement . But, remember the drive slot is proprietary.
из
Добавьте свой ответ
Luke James Langpap будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 8
За последние 30 дней: 8
За всё время: 182
