Guides and support for various television (TV) brands and styles.
9055вопросов Показать все
Board Swap in Sanyo Dp46841
I have a Sanyo DP46841 with boards numbers 1LG4B10Y069A0 Z5VGE(main),1LG4B10Y048C0(Power)1LG4B10Y083BAZ5GE,I found a bundle of boards with exact numbers except the suffix is ZVHE,will they work with my panel if I change all three boards….your help is greatly appreciated
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Hi @bull40dawg ,
Did you mean suffix Z5VHE?
Checking the following links the mainboard- LG4B10Y069A0 Z5VGE and mainboard - 1LG4B10Y069A0 Z5VHE may be compatible. The Z5VHE board covers more model variants.
The DP 46841 02 P46841 02 model is covered by both boards.
You don’t mention the suffix for the Power board and the link doesn’t mention Z5VGE only ZVG but the DP46841 02 model is mentioned.
I cannot find any information regarding the last number (1LG4B10Y083BAZ5GE) that you mentioned. Could you please verify that it is correct?
This link also failed to find a 1LG4B10Y083BAZ5GE board or a 1LG4B10Y083BAZ5HE board. (or even a 1LG4B10Y083BAZ5VGE or 1LG4B10Y083BAZ5VHE board)
You could always contact the supplier in the link and find out if all the boards are compatible.
Hopefully this is of some help
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
James Miller будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 58
