The OnePlus 7 Pro is an Android smartphone from OnePlus. It was released in May 2019.
Is It difficult to change the glass back cover?
My phone fall near to the floor and has broken the glass of the back cover. I am thinking about any kind of way to repair it.
Any advice? Thank you.
Это хороший вопрос?
Счет 4
Добавить комментарий
1 ответ
Выбранное решение
No, it really isn't. Just use a heat gun and pry the sides open with any plastic cards or such. Before taking the whole back glass apart, disconnect the camera cable and you'll be fine. You might want to use the old camera gasket and materials if the new glass back doesn't come with it.
Был ли этот ответ полезен?
Счет 4
2 Комментариев:
Is there a comparable guide demonstrating how to do this?
из
@psiufoxx take a look at the first few minutes of the teardown on here OnePlus 7 Pro Teardown to see how to remove it. Do not forget to remove the camera flex cable.....
из
Добавьте свой ответ
Pablo буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 4,532
