clincking on and off
turn tv on cut back off
Это хороший вопрос?
Clyde Haynes not a lot of description here :-) . For now I suggest that you might want to consider checking the no power flow chart. Your issue appears to be related to the power failure circuit. You will need a multimeter to check those components.
you also want to check on the power failure circuit
Let us know what you find. Another thing that can be helpful to find an answer is you adding some good pictures of all of your boards with your question. Adding images to an existing question
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 7
За всё время: 40
1 Комментарий
https://www.ifixit.com/Answers/Device/Sa...
из prop man
