Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
Superdrive replacement
Hi!
I'm having trouble with my Superdrive Pioneer DVR-K06 and need to replace it.
Jason, you wrote that you have replaced it with a Matshita Blue-Ray, how did you do it? I'm very interested in if it is possible to replace the superdrive with any slim DVD/BR device?
I'm in desperate need for help, I have a stuck CD in the superdrive and it keeps trying to eject it, unsuccessfully!
Это хороший вопрос?
Счет 2
1 Комментарий
If you still have the stuck disc problem: • try to eject while in Toast Titanium 9 (or newer). It has an eject option which has proven very useful for me in the past when I have had the same problem. • hold down the mouse button on restart until the disc ejects. • drag the disc icon to the trash • try eject from iTunes • Open Terminal and type "drutil tray eject" to eject the disc/tray • Good luck. I hope this helps.
из
Добавить комментарий
1 ответ
Выбранное решение
I replaced it with the help of this guide. It was a little bit tricky but easy overall. Patience is necessary.
Был ли этот ответ полезен?
Счет 3
Добавьте свой ответ
Jonas буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 913
